Ace broken charger
My daughter got her Fitbit Ace for Xmas, the charger has broken & now she can’t charge it ☹️
4 REPLIES 4
Hi, @Sinead40 , as you posted twice about the same issue, I have merged your posts.
I have flagged your post for moderator attention, amd someone should be along shortly to get some more information from you and to follow this up with Customer Support in order to get your daughter back up and tracking her steps again.
In the meantime if you would like to read about Fitbit's limited warranty, which applies to chargers as well as the tracker itself, there is a link at the bottom of every page Community forums.
Thanx Julia,tried to delete one of them but I couldn’t figure out how🤷🏻‍:female_sign:
Hi @Sinead40, for future reference on how to delete a posting, hover over the top right hand corner of the screen and select the 3 dots.  From there, you will have an option to either edit or delete your post.  Select which one you would like to do, and you will be taken to the appropriate page.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Hey @Sinead40, it's great to see you around. @Julia_G and @DramaQueenDiva thanks for the input.
Regarding your daughter's Ace charging cable, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
