06-06-2018 11:44
06-06-2018 11:44
I recently purchased two Aces for my sons. I was able to create a family account and add both of my sons. I setup the first Ace with no problems and connected it to my sons account. When I tried to add the second Ace to my other sons account, I keep getting the error 500. I have talked to multiple people at Fitbit and get a different answer every time. I hope it gets resolved soon so my sons can both enjoy their Aces!
Best Answer06-06-2018 12:46
06-06-2018 12:46
Error 500 usually appears when your device's OS has a pending update. You might want to update the software on your phone.
Also make sure that the Fitbit app is up to date. You can check and update in the respective application store of your device (App Store, Google Play, Microsoft Store). Most of the time the updates will be installed automatically. And the last and maybe most important thing is to make sure your mobile device is compatible with the Fitbit app and the devices. You can check which devices are fully compatible here: Which phones and tablets can I use with my Fitbit watch or tracker? This is a very important thing to check because if your phone is not fully compatible you'll face some syncing and accuracy issues. Hope this helps you set up the Aces and get your kids up and running. If not you can try the troubleshooting form the Help Site:
Aaand if this doesn't help you, you can contact the support team. Most of the times they have an explanation about the issue or other troubleshooting methods. Cheers!
Best Answer06-06-2018 13:42
06-06-2018 13:42
@Gufi I have tried all of those suggestions with the exception of removing all other Fitbit devices from my phone. I am hesitant to do that for fear that my other devices won’t connect again after I remove them. I have a Versa and one Ace connected now. Both my iOS and the Fitbit app are up to date.
Best Answer06-06-2018 13:44
06-06-2018 13:44
@Gufi I have also contacted the support team and their response was that it is an iOS issue and hopefully it will be resolved soon. It’s confusing too because I was able to connect one Ace, just not the second one.
Best Answer06-06-2018 13:50
06-06-2018 13:50
@Cheesamarie yeah I thought so. This is usually an internal error. I wouldn't remove any devices from your account because at the end of the day they aren't causing the issue, at least I would think so.
You can however, move them away or turn them off if possible because they other trackers may still interfere with the connection.
Again, if you haven't done so, try another device, phone or laptop, doesn't matter as long as it's compatible and up to date.
Otherwise, if you have your receipt and the device is within the warranty policy just get back to support and they'll surely help.
Best Answer06-09-2018 19:13
06-09-2018 19:13
The IosIboard has plenty of posts on the error 500.
The quick but dirty fix i can think of would be to borrow an Android or Windows phone from a friend with a Fitbit.
.Log out of their account, log into your account switch to your family account .
Add the Ace to your sons account .Then switch back to the main account. you are now logged out, and your friend may have their phone back.
Next time you open your IOS Fitbit app, you will see that both sons have a tracker connected to their accounts.
