Hi All,
I set up the Fitbit Ace for my daughter a couple of weeks ago, she has since seen her sisters display settings (clock display and a different step display) plus that her sisters is showing the battery availability; hers is not.
Can anyone advise how I change the screen settings and add the battery display.
Thank you in advance.
Kim.
@Kim-C-86 To see the display options, go to Fitbit App > Account > Ace > Clock Display. There are 5 horizontal, and 5 vertical options to choose from. I have not seen a battery life option though. Closest one I saw was the face with 5 dots which shows progress toward the child’s goal.
@Kim-C-86 welcome to our Fitbit Community! By the way, I'm sorry for the late response. However, I would like to follow up and would like to know if you were able to change the clock face after following the great workaround that shared my friend @Jrdubyakc.
If you found her post helpful, please accept it as a solution so other users that have the same question can find it easier.
Looking forward to your response! ![]()
