12-26-2018 07:31
12-26-2018 07:31
My daughter just got her Ace for Christmas. She woke up with 50 steps,walked about 20 steps downstairs and had 90 steps. Is this normal. I’ve tried to reset but it doesn’t seem to work.
12-26-2018 17:52
12-26-2018 17:52
@tigerlilyjk Welcome to the Fitbit Community.
I'm sorry to hear that your daughter's Fitbit Ace is counting too many steps. Thank you for restarting the Tracker before contacting us. This is definitely not an expected behavior. I would recommend setting the hand to dominant in order to decrease the sensitivity of step counting and reduce any over counting of steps when her body is not moving. Please go to account > Devices > Handedness setting. Make sure to sync after making any change to the account.
The restart process doesn't delete the information recorded but is more likely used to resolve syncing issues.
If you have any question, please let me know.
Best Answer12-27-2018 12:28
12-27-2018 12:28
My daughter also received one for Xmas and having same problem. I tried the above but there’s no option to set to dominant on hers. Only left or right ? Any other ideas?
Best Answer12-27-2018 16:52
12-27-2018 16:52
@RichMelLil It's great to see you in the Fitbit Community.
Sorry for the misunderstanding, I meant the user can wear the Fitbit Ace on the right or left hand but if their dominant hand is left that should be set on the Fitbit account.
If the above doesn't help, please let me know in order to contact Customer Support for further investigation.
Best Answer01-13-2019 19:15
01-13-2019 19:15
my daughters ace is also counting double steps. this just started yesterday. she sat and did literally nothing all day and had 7000
Best Answer01-13-2019 19:16
01-13-2019 19:16
same thing is happening to my daughter. Did you solve the issue?
Best Answer01-14-2019 18:26
01-14-2019 18:26
@darcyf Thanks for visiting the Fitbit Community.
If you haven't done it already, please perform a restart to your daughter's Fitbit Ace by following these steps. If this doesn't help, ask her to wear it on the other wrist to see if there is any improvement.
Please let me know how it goes.
