08-17-2018
17:23
06:07
JuanJoFitbit
08-17-2018
17:23
06:07
JuanJoFitbit
My daughter received a Fitbit Alta hr a few months ago and loves it but the wristband is too big. Now that the Fitbit ace has come out I want to purchase a band for her so that it fits but I can’t find only the band anywhere. Please let me where I can find them. Thanks
Moderator edit: format
@Dance24 Welcome to our Fitbit forums! I'm sorry to hear that your your daughter's Fitbit wristband is too big. However, I want to follow up and would like to know if you found @Odyssey13's information helpful since that is the correct information about the dimensions of the trackers' wristbands.
See you both later! ![]()
Hi @Dance24
The Fitbit Store has the Ace bands - blue or purple. click to go there
Checking the band measurements:
Ace : One Size; fits wrists 5.0” - 6.34" in circumference.
Alta HR (bands also fit the Ace)
Small : Fits wrists 5.5" - 6.7" in circumference
Welcome to the forums! Let us know what happens with your daughter.
Alta bands will also work if you can't find an Ace band.
one cruise ship at a time!
08-25-2018
18:18
05:21
JuanJoFitbit
08-25-2018
18:18
05:21
JuanJoFitbit
Thank you odyssey13, I will look into this!
DramaQueenDiva, yes but I was looking for something smaller that the Alta band but fit the actual Alta Fitbit if that makes sense. Thanks for the suggestion though!
There are many third party Alta/Alta HR bands on Amazon, with many smaller than fitbits.
Amazon also has many third party bands for the Ace.
09-19-2018
05:20
04:05
09-19-2018
05:20
04:05
@Dance24 I'm glad to hear that you found @DramaQueenDiva and @Odyssey13's information helpful. Thank you for your feedback.
@Rich_Laue Thank you my friend for sharing more helpful information!
See you all later! ![]()
