Replacement bands for Fitbit Ace
ANSWERED
My daughter received a Fitbit Alta hr a few months ago and loves it but the wristband is too big. Now that the Fitbit ace has come out I want to purchase a band for her so that it fits but I can’t find only the band anywhere. Please let me where I can find them. Thanks
Moderator edit: format
1 BEST ANSWER
Accepted Solutions
@Dance24 Welcome to our Fitbit forums! I'm sorry to hear that your your daughter's Fitbit wristband is too big. However, I want to follow up and would like to know if you found @Odyssey13's information helpful since that is the correct information about the dimensions of the trackers' wristbands.
See you both later! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
6 REPLIES 6
Hi @Dance24
The Fitbit Store has the Ace bands - blue or purple. click to go there
Checking the band measurements:
Ace : One Size; fits wrists 5.0” - 6.34" in circumference.
Alta HR (bands also fit the Ace)
Small : Fits wrists 5.5" - 6.7" in circumference
Welcome to the forums! Let us know what happens with your daughter.
Stepping in the U.S.A. since September 2013. Android 14
Alta bands will also work if you can't find an Ace band.
one cruise ship at a time!
Thank you odyssey13, I will look into this!
DramaQueenDiva, yes but I was looking for something smaller that the Alta band but fit the actual Alta Fitbit if that makes sense. Thanks for the suggestion though!
There are many third party  Alta/Alta HR bands on Amazon, with many smaller than fitbits.
Amazon also has many third party bands for the Ace.
@Dance24 I'm glad to hear that you found @DramaQueenDiva and @Odyssey13's information helpful. Thank you for your feedback.
@Rich_Laue Thank you my friend for sharing more helpful information!
See you all later! Smiley Happy
