11-18-2017
02:28
20:08
11-18-2017
02:28
20:08
Hi, does anyone know how to add a tile to my Alta Hr? I accidentally deleted my sleep tile on my dashboard? Any help would be appreciated. Thank you.
Tap the plus sign in the green circle on the bottom right and you should be able to select the sleep tile. If it doesnt appear you will need to uninstall your app and reinstall it. Then you should be able to re add it. Let us know how you go.
Helen | Western Australia
Best AnswerI did this I do not see a green circle in the bottom right. I reinstalled the app and tried and still do not see it.
