07-01-2022 18:33
07-01-2022 18:33
Hello,
I am trying to hand down my old Alta HR to my 13YO to use. I tried to set up a family account, but those are just for Aces. My child does not have a cell phone, so I would like to sync the Alta with mine. Is there a way to have both the Alta and my own Fitbit synched to my phone on a family plan or something else? Thank you in advance for the help.
07-01-2022 19:33
07-01-2022 19:33
Hi @DPWalker easy to do. Get your child an email address (so many places offer them free - mail.com is one I've used) and then you can set them up on your phone. Be sure you're logged out of your app and get your device at least 25 feet away while you set up the one for your child. Set it up as usual and then log them out. Then log back into your account and whenever you want to sync and check stats, just log in and out to see them. If your child has access to a computer or tablet, they can also see their stats (not sync, but see) that way. You can make this work and you can do challenges, too.
