Hi
Gotten my Alta HR for 3 years
And since last year the lights are getting dimmer and dimmer ....
I can't even read the timings during the day , especially when outdoors ....
Can somebody help ..? I love the design so much and wouldn't want to change another watch ..
Hi @maseratiapple Try restarting it several times, but if that doesnt help then there is nothing you can do. If you do need to buy a new tracker, the Inspire series are quite similar to the Alta series, so have a look at them.
Helen | Western Australia
Best AnswerPlease clarify... are you saying FitBit is only good for a short while after warranty expires? Built in obsolescence? What a shame. I’ve loved my Fitbit Alta HR, but not into dishing out a couple of hundred dollars ++ every two years.
