04-04-2020
08:59
19:37
04-04-2020
08:59
19:37
Since Thursday I have had to charge my fitbit alta HR 3 times. Additionally my HR wont turn off, even though my settings are set to auto. Last night I reset it & charged it. When I took it off the charger this morning it was working for a few hours. I put it back on after my shower & the screen was blank. I hooked it back up to the charger & only get the fitbit symbol & a battery with an "!". It does not vibrate when I hook the charger up & does nothing when I try to restart. Also when I tried to sync it this morning before it stopped working it would not sync. Thanks for your help. Brandie
04-04-2020 09:27
04-04-2020 09:27
Now I hook it to the charger & suddenly it goes from a battery with "!" to fully charged. But if I unplug it goes back to being blank.
04-04-2020 16:58
04-04-2020 16:58
Just had exactly the same only a year and a bit old, battery showing the ! sign in it, done a restart shows battery as being fully charged then discharges in a matter of minutes. An expensive piece of equipment if it only lasts 18 months and the battery cannot be replaced. I have emailed Customer Support
04-04-2020 17:26
04-04-2020 17:26
Where did you find an email for customer support? When I click help I dont get an option to email. Thanks.
04-05-2020 07:38
04-05-2020 07:38
Same thing just happened to me yesterday as well. Anybody know what's going on????
04-05-2020 08:05 - edited 04-05-2020 08:08
I am having the same issue. It start a day or two ago. I thought something was wrong with my Fitbit and do not have the money for a new one with job situation right now. Not sure how to contact support either.
Best Answer04-05-2020 08:52
04-05-2020 08:52
I chatted with customer support this morning. She said my device needed to be replaced. I was outside of my warranty but received a discount code to buy a new one.
Best Answer04-05-2020 09:12
04-05-2020 09:13
04-05-2020 09:13
Yep all the batteries are dying out the same time. You can't replace them so that's it you have to buy a new one and as you see they may send you a discount code to buy another of their products that will again only last a year or so. What a joke of a product.
Best Answer04-05-2020 09:15
04-05-2020 09:15
https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs can find it through the home page
Best Answer04-05-2020 09:58
04-05-2020 09:58
Same here. Out of warranty sent me a coupon. What a joke is right. Can anyone recommend a similar but more reliable fitness tracker?
Best Answer04-05-2020 14:46
04-05-2020 14:46
Of course these things die after a few years, they are electronics. Electronics that are used daily. Fitbit offering a discount after the warranty has expired is pretty good customer service. I was ready to buy a new one even without the discount. I'm satisfied with the results I received after chatting with customer service.
04-05-2020 16:16
04-05-2020 16:16
Few years? It's lasted 10 months. More fool you is all i can say
Best Answer04-05-2020 17:17
04-05-2020 17:17
10 months? Yesterday you said 18 months. That is a big difference. I'm not a fool, you are just an unsatisfied person.
Best Answer04-05-2020 17:20
04-05-2020 17:20
It was brought 18 months ago I only started using it in May dullard. That can be proved my dashboard not that I have anything to prove to you. You're clearly thick enough to keep throwing good money after bad on crap products . Bravo
