07-11-2023
19:25
07:56
07-11-2023
19:25
07:56
For the last few days, every time I try to sync I get an error message, so I do all the tricks: force stop, uninstall and reinstall, unpair and repair device, and restart phone. No rhyme or reason to what will work to get it going again. Am I the only one with this issue? Is if just because the Alta HR is old so they're causing bugs to get us to upgrade??
07-13-2023 07:09
07-13-2023 07:09
Hi @Pamthetvaddict No, I doubt it is deliberate on Fitbit's part. But the truth is the Altas ARE old devices now and are subject to failure. Also they are further away from the era of the phone's we are using now so they are less compatible. However, you should still be able to get them to sync, assuming there isn't an age related problem with your Alta. What I have always found works for me is to RESTART my tracker a few times, then go to my phone and unpair my tracker from the phone's Bluetooth settings and turn off bkuetooth, restart the phone and turn bluetooth back on and then go to the fit it app and try to sync again (don't try to pair the tracker through the phone's Bluetooth settings - that won't work). If that fails then have a look at THIS Help Article on Syncing Issues and give all the suggestions a try. Good luck.
Helen | Western Australia
07-14-2023 07:59
07-14-2023 07:59
Hello there, @Pamthetvaddict. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Alta HR before reaching out.
In addition to the steps recommended by @NellyG, please try following these steps in the order listed:
With the steps above, what I want you to do is to pair your Alta HR first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer07-23-2023 04:50
07-23-2023 04:50
I am going thru this also. I reinstalled it but the devise doesn't show on the Bluetooth. I haven't been able to see the screen for ages but that isn't the issue it's being able to pair. A different style of screen has come up as well.
I don't see my sleep or heart rate. Or rather it's not recording it.
