01-13-2023 12:47
01-13-2023 12:47
I have an alta and have had to stop using it. It is fully charged, the screen "responds" only when it is on the charger but only once. Once I remove from the charge, it does not respond to taps or to wrist movement. I have followed the instructions to restart the alta but that is not successful.
Any other way to get the Alta to start responding?
01-13-2023 15:08
01-13-2023 15:08
Have you tried to reinstall the app?
Best Answer01-13-2023 19:01
01-13-2023 19:01
Best Answer01-14-2023 09:08
01-14-2023 09:08
@Auntie-J I'm not sure when you bought your Alta, but Fitbit only made them between 2016 and 2019. That means that yours has to be at least four years old. Rechargeable batteries have a finite life span. Unfortunately, it sounds as though the battery in your Alta may be at the end of its life. If that's the case, there isn't any way for you to revive it.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
Best Answer01-14-2023 09:57
01-14-2023 09:57
Best Answer01-14-2023 10:00
01-14-2023 10:00
Call support, they were very helpful and resolved my issue yesterday after only a 3 minute wait 🙂
