My Alta is charging fine, but the charge doesn't hold for more than a day. Can this be fixed?
Hi @MarshaSachs Basically, no. Once a battery starts to die there is nothing you can do. The Alta is pretty old as far as trackers go, so it has done well to last this long. Try restarting it several times to see if that helps, but I kind of doubt it at this age. I think you need a new one.
Helen | Western Australia
Thanks, I did try the restart and it seems to have worked.
Yee haaa! That is great!
