03-14-2021 10:22
03-14-2021 10:22
Hi , I think I have a Fitbit Alta Hr 101. I haven’t used it in a while and the battery is flat. I ordered a replacement charger however it doesn’t appear to fit.
My device has three horizontal dots and then two vertical dots below but the charger I received only has two dots.
Any help on where I can find the right charger welcome
03-14-2021 10:31
03-14-2021 10:31
Hi @Raaaa have the same Alta HR myself and am using the original charger that came with it. It only has two metal prongs or dots on the charger, despite having three dots on the actual Fitbit. Where did you purchase the charger? It should have a button on it to do the restart of the device. You can buy Fitbit accessories at the Fitbit online store upper right of this page. Sometimes these devices are left with a dead battery too long to return to life, too.
03-14-2021 10:41
03-14-2021 10:41
Thank you for getting back so quickly @Odyssey13 . I should have said I’ve lost the original charger.
The charger I bought was from Amazon and the two dots don’t even line up. The charger ones seems to come up higher.
Could you point me in the right direction of the charger I would need?
Best Answer03-14-2021 11:29
03-14-2021 11:29
@Raaaa you could check local authorized retailers in your area to get it faster. The Fitbit Store lists a charger for the Alta, but it doesn't say if it's for the Alta HR, so I'm going to ask a moderator to confirm it would work with the Alta HR. Here is the link to the charger.
Best Answer03-14-2021 11:47
03-14-2021 11:47
Thank you @Odyssey13 If you could let me know if that would work for the Alta HR that would be amazing. Do you know if the store ships to the uk?
Best Answer03-14-2021 11:53
03-14-2021 11:53
The moderator would know more about that. Could be there is a retailer in the UK who does sell these @Raaaa
Best Answer03-14-2021 12:02
03-14-2021 12:02
Thanks. Who is the moderator so I can check these things? @Odyssey13
Best Answer03-14-2021 13:02
03-14-2021 13:02
I asked a moderator to stop by this thread, but I have no idea which one will get the message to respond. They stop by as they are able. I doubt the UK customer support is available this late in the day.
Best Answer08-09-2021 21:22
08-09-2021 21:22
Hi Odyssey.. sorry to interject this thread .. I am based in Singapore and I needed the charger for my Alta HR. I have contacted Fitbit and they told me it’s no longer on sale online. The link which you indicated here is not working . I tried contacting all the authorized distributors in my country and they told me they not carrying this model as it’s obsolete. I tried buying those OEM ones but somehow they just don’t work! Do u know how else I can get the charger ?
much appreciated
Best Answer08-09-2021 21:38
08-09-2021 21:38
Hi @Elainechan the link was from March and it no longer shows the charger as being available. See if you can find one on Amazon, but be sure the charger unit has the button on it, which is needed to do a restart of the Fitbit. The Alta series was replaced by the Inspire series, which was then replaced by the Inspire 2. So you might need to go to eBay or any third party retailers to find the right charger unit.
Best Answer08-09-2021 23:18
08-09-2021 23:18
Thanks for your prompt reply
