04-02-2020
09:29
19:37
04-02-2020
09:29
19:37
How to amend to GMT 24 hour clock?
04-02-2020 10:40
04-02-2020 10:40
Hi, @PO5! Go into your settings (https://www.fitbit.com/settings/profile) and under advanced settings you will see clock display time. You can change the setting there.
MakMak | Community Council
04-02-2020 10:40
04-02-2020 10:40
04-02-2020 10:49
04-02-2020 10:49
@PO5 It also sounds like you are asking about a 24 hour clock instead of a 12 hour clock. If you are trying to get a 24 hour clock, you must make this change on your fitbit.com (web) dashboard.
If this is what you want, you only need to make this change once. If you add any other devices to your account, they will be on a 24 hr clock.
Laurie | Maryland
