10-27-2016
06:29
18:17
10-27-2016
06:29
18:17
10-27-2016 07:49
10-27-2016 07:49
That's really weird. Can you wear other bracelets? Does carrying your phone give you a headache?
Best Answer10-27-2016 10:45
10-27-2016 11:05
10-27-2016 11:05
02-06-2017 06:21
02-06-2017 06:21
I had the same exact experience one day after using my fitbit. As an RN, I don't see a physical correlation but there is one that's not yet know. Thanks for posting this so the problem can be noticed and corrected.
08-31-2017 04:27
08-31-2017 04:27
I have been having horrible headaches and being nauseated this is my 5th day of this. And I took off my Fitbit Alta last night to charge and the headache eased up through the night . I put it back on this morning and within an hour I started getting the headache again.
I've never heard of any reports of them causing any issues SO I wanted to buy one to track my daily calorie burn and heart rate. But idk if I will keep it if it's going to make me feel like this. I've never had severe headaches before wearing it. And it's not worth it if it is the issue. I am Glad I looked it up to see if anyone else felt this way!!.
I've never been one tho to be able to wear watches battery seems to die fast. I have neck issues I've had disk fusion but never felt like this. I've wore it for 6 days and 5 of them has been horrible headaches.
07-24-2020 10:57
07-24-2020 10:57
I had head pain too wearing the fit bit, really strong pain. I think it is the bluethooth becaus some people feels more EMF radiation than others, today i use apple watch with airplane mode always on and it s ok for me.
Best Answer12-09-2021 05:17
12-09-2021 05:17
Haberlid It is not your imagination. I experienced the exact same symptoms. I thought I was the only one wow! that I assumed that the laser was reacting harshly to my system. All electronics including cellphones have nickel and some people are allergic. I think that is why Fitbit suggest to try out and if it doesn't work to simply return it within 15 days no questions asked. If it wasn't for the migraines I absolutely love the product and features.
Best Answer12-09-2021 05:20
12-09-2021 05:20
Thank you for your post I hope they fix this issue.
