Hi, @Nustine , you should be able to see this on your Fitbit and also on your app.
The vertical clock faces will give total steps rounded to the nearest hundred (for example 1.2k steps = 1200 - 1249 steps) and the horizontal clock faces should show the exact total.
If you need more help, pleas post again, with as much information as possible.
