08-20-2016
09:14
21:33
EstuardoFitbit
08-20-2016
09:14
21:33
EstuardoFitbit
I rode the stationary bike at the gym for 45 minutes yesterday and my Alta did not track it. I thought it tracked stationary bike movement?! It's only day 4 of use and I've had so many questions...ha ha ha
08-21-2016
02:11
12:33
08-21-2016
02:11
12:33
Hi, @NavyLady, the Alta only automatically tracks outdoor bike, because it needs to detect forward motion.
The best thing to do for stationery bike is to log it manually. Instructions here: https://help.fitbit.com/articles/en_US/Help_article/1144
Best AnswerI have not been sucessful in recording stationay bike activity. I use treadmill and eplitical trainer and it records steps fine. I discovered if I remove the fitbit and put in my pocket it records just fine.
12-01-2016
07:09
12:34
12-01-2016
07:09
12:34
Hi there @beerbasket! ![]()
As my friend @Julia_G kindly explained in her post above, the Alta trackers outdoor bike only. It can track a treadmill and elliptical activity properly, because it is designed to track those two activities, but for cycling, it needs and actual distance traveled, in order to track.
One more thing to mention is that the tracker is designed to be worn around your wrist. Keeping it in your pocket can cause it to fall or not track properly.
Keep me posted if you have any questions! ![]()
Was my answer helpful? Awesome! Let's help our fellow Fitbitters by marking this as a solution, and vote up! 😄
I put my alta in my pocket because the strap slips off. It tracked my stationery biking. I did a little research and deduced 1 step may burn a little more than one cycle, but it helps. I just take take the few extra (in reality) unburned calories tracked by my Alta, as the caloriea burned during untracked exercises like pushups. Hope this helps.
