02-19-2019
06:44
06:26
AlvaroFitbit
02-19-2019
06:44
06:26
AlvaroFitbit
I have both an Alta HR and a Flex 2 and cannot sync either one of them. My Flex2 won't charge anymore. The last time I was able to sync was Feb. 6th. Please FIX this. I have spent too much money on your products for the app to not be working for do long. I am not the only one having this problem. Do you read these notices? Do you respond to them? Frustrated!!!
02-19-2019
08:34
06:27
AlvaroFitbit
02-19-2019
08:34
06:27
AlvaroFitbit
Hello and welcome to the forums @PSteb
Yes, Fitbit does have moderators who keep an eye on these posts, but I'm going to ask one of them to stop by to help you out.
How are you syncing - computer or mobile device, Android, iOS or Windows? The more we know, the better to assist you. This article is for trouble syncing - click to read and an article on restarting the devices - click for that one
You'll recognize a moderator was they will have "Fitbit" after their name.
@PSteb Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your trackers aren't syncing with your phone and that your Flex 2 isn't charging. For the syncing issues I would like to know which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
To help your tracker charge try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
@Odyssey13 thank you for helping here.
Let me know how it goes!
