23:26
13:12
04-07-2022
23:26
13:12
Hi @cawolfe39 - what Bluetooth device are you using to measure temperature?
You could make the suggestions here https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
The Fitbit App temperature tile graphs skin temperature and allows manually entering core temperature to 2 decimal places [but only shows to one] and provides no graphing for either.
Skin temperature is shown as deviations on a moving baseline and is only an indication that can easily be affected by environmental conditions.
Given you already have a good recording of temperature in your current apps it is improbable that Fitbit will consider adding it to their app even though the idea is a good one.
Best AnswerI am using a Kinsa QuickCare thermometer which is connected with Bluetooth to their app. It has no charting features. I disagree somewhat with the statement that I already have a good recording of temperature. While I do have a good record of the raw data, this data would be more useful if presented in a good chart, like the one that Fitbit provides for body weight.
I mentioned MedM; I recently discovered that I am unable to connect my Kinsa with their app. So I am really only concerned with the Kinsa connection.
