09-04-2019
00:44
14:55
LizzyFitbit
09-04-2019
00:44
14:55
LizzyFitbit
Hi!
I got a new phone, samsung a40 and now my charge 2 isn't pairing. I've uninstalled the app/reinstalled the app and unpaired the original sync but nothing is working. I reach the part where you type in the code and it stops there, unable to sync or pair. Help!
Best Answer09-05-2019 14:54
09-05-2019 14:54
Hi @FarmerGeorge. It's great to see a new member around.
Thanks for sharing details about your Charge 2, and your phone's model. You did a good job with the steps and let's work on this together. First of all let me share that your Samsung Galaxy A40 isn't a supported device, meaning that the Fitbit app hasn't been fully optimized for this model. While there isn't a guarantee, it might be able to work as before so let's recommend to try the following troubleshooting steps:
Give it a try and keep me posted!
Best Answer09-06-2019 13:12
09-06-2019 13:12
I'm afraid that hasn't worked but thank you for trying
Best Answer09-08-2019 13:53
09-08-2019 13:53
My wife has a similar problem with her Charge 2 and new Samsung Galaxy A10. We get as far as receiving a 4 digit code on the Charge 2, but the connection process fails to get any further. This was the case before and after following the steps above.
Best Answer02-28-2020 08:07
02-28-2020 08:07
Given that there are clearly a number if A40 users out there unable to connect our fitbits, is there any intention to support this phone? I can't believe it would be difficult for you to support all the major current phones
Best Answer02-28-2020 08:53
02-28-2020 08:53
I got my samsung a40 july 2019 and have had problems syncing intermittently ever since! I've had my fitbit alta for several years now, never thought I'd have to check what phone I upgraded too would need to be checked to ensure it was compatible with fitbit!!!!!
