05-01-2017 02:50
05-01-2017 02:50
My charge 2 synchs sleep stages...but only every other night, defaulting to the old ways the rest of the days. Seems strange that it works sometimes, but not consistently. Advice?
05-01-2017 03:09
05-01-2017 03:09
Fitbit say there are a few things that might stop sleep stages recording on a particular night:
"WHY DON'T I SEE SLEEP STAGES TODAY?
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
taken from: https://help.fitbit.com/articles/en_US/Help_article/2163/
05-01-2017 08:27
05-01-2017 08:27
My charge 2 stopped recording sleep stages on Friday the 28th. Reverted back to old way since then. Always worn same arm and place. Would like to get stages back. Any other ideas.
05-01-2017 13:25
05-01-2017 13:25
@Mjcar Fitbit estimates your sleep stages using a combination of your movement and heart-rate patterns. While you’re sleeping, your device tracks the beat-to-beat changes in your heart rate, known as heart rate variability (HRV), which fluctuate as you transition between light sleep, deep sleep, and REM sleep stages. If we don’t have enough information on the backend to calculate this, we’ll show you your old sleep pattern which doesn’t require heart rate. You may want to check the fit of your Charge 2 to make sure we get a good heart rate signal. Click here to learn more about how to check the fit of your tracker.
@Dr.Elaine It appears that your Charge 2 tracker is no longer paired with your account. To pair the Charge 2, check out the instructions here.
Once the Charge 2 is paired, give it another chance at tracking your sleep overnight. Let me know of the results.
Best Answer05-02-2017 15:19
05-02-2017 15:19
I believe there is a bug with the sleep tracker update for the Charge 2 and android. I looked at it a few minutes ago and the dashboard showed me having slept almost 15 hours today. I drilled down and saw it combined both Monday's and Tuesday's hours. I tried deleting and reentering my sleep time for today. Still got combined hours on the dashboard. I updated the app and although the drill down on sleep shows the daily amounts, the main dashboard (old one, don't like the new one) shows no sleep logged. I did make sure my tracker was synced to my computer and all is fine there, just an apparent Android device problem.
