11-21-2019
08:50
16:29
LizzyFitbit
11-21-2019
08:50
16:29
LizzyFitbit
My tracker stopped syncing with my fone on Tuesday evening. Got myself very frustrated trying all sorts of things and finally removed my tracker from my account and tried to set it up again - Oops, now it won't pair - I keep getting a four digit code which I type in, but it doesn't work. My phone scans for my tracker and finds it, but can't pair with it. Please help. Thanks.
11-21-2019 16:41
11-21-2019 16:41
Hi @Southerner. It's nice to see a new face around the Forums.
Thanks for your efforts while trying to pair your Charge 2 with your phone. This shouldn't be happening and to further investigate may I know your phone's model and Android version? Is the Fitbit app also updated to the latest version?
Although you've tried some steps, I'd recommend to try the following:
Give them a try and keep me posted.
Best Answer11-21-2019 21:07
11-21-2019 21:07
Best Answer11-23-2019 00:19
11-23-2019 00:19
I've tried your suggestion too (and all the others too!!!) - didn't work for me. My fone stoped syncing with my tracker so after much frustration I deleted the tracker (Charge2) and removed it from my account. Now can't set it up again. Bluetooth on my android scans for available devices, finds it but immediately says it can't pair with the device. When I try and set it up again through the app on the fone, it finds the tracker, I get a 4 digit number to input then it tells me bluetooth is not working! Please help. Thanks.
Best Answer11-23-2019 06:54
11-23-2019 06:54
It didn't work!!
Best Answer11-23-2019 09:25
11-23-2019 09:25
All you should have to do is make sure that your phone is not paired by Bluetooth with your charge 2. Then open or reinstall the Fitbit app and go to the ‘notifications’ section on the app it should immediately prompt
tp pair. That’s for an iPhone maybe it’s different for android.
Best Answer11-25-2019 09:40
11-25-2019 09:40
To say that I am disappointed is an understatement. I still have not had my problem resolved and after having read through other messages, it seems to me that a lot of different trackers are having problems synching and pairing with different makes and models of fones. The same 'advice' is given by different moderators to all the problems and this 'advice' does not work. Guess what, tomorrow I go and buy a totally different make of tracker. Sorry to say this, but thanks for nothing Fitbit.
11-25-2019 17:27
11-25-2019 17:27
Has anyone had luck.in getting their charger 2 to sync with their Samsung A8 yet?
I tried all these things and still no luck!
