05-21-2020
05:06
16:48
RicardoFitbit
05-21-2020
05:06
16:48
RicardoFitbit
Upgraded phone charge 2 won't sync to my Samsung s9... keeps saying make sure my fitbit is charged (it is) and then when i try to sync it says can't sync then says turn phone bluetooth off and back on... been doing this for 2 days and it's not working
Hi, and welcome to the Community!
Do you still have your old phone? If so, make sure it doesn’t still have a connection to the tracker in its bluetooth settings as this could be blocking connection to your new phone.
05-22-2020
16:48
11:39
05-22-2020
16:48
11:39
Hi @Ronaldwood82, welcome to the Community Forums!
First, I appreciate your effort and patience for troubleshooting this situation prior to posting. If you haven't already done so, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your Android mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
@SteveH Your support is always appreciated, thanks for the helpful information that was shared.
Keep me posted, I'll be around if you need anything else.
