03-05-2018 23:16
03-05-2018 23:16
I have a Charge 2 that used to work. Now I can't get it to record steps or sleep on my Google Pixel 2 XL or my MAC laptop. I put all the notifications on, but nothing. The last time it sync'd was Feb. 18. It was working, stopped, started working sporadically, and now does nothing. It is listed under Paired devices for Bluetooth, but if I click on it, it shows a connect button that does not respond.
It is so frustrating that there is no Customer support for Fitbit. Once you buy it, you are on your own with issues.
What has happened? it used to work without issue. Now I'm getting ready to just throw it away as it is so frustrating. Any suggestions?
Best Answer03-06-2018 08:58
03-06-2018 08:58
Hi, @Maryann6! A few things: first, have you tried restarting your tracker several times? Second, a number of people on Android, myself included, had recently had issues with syncing. For me, they were actually somehow mostly resolved on the current app version, but there is a new app version rolling out soon that should help with the syncing. I would check your app store to see if you have that yet. Finally, there is an option to contact Fitbit Support directly, usually via email, chat, or phone here. They can also help you troubleshoot.
MakMak | Community Council
Best Answer03-06-2018 23:45
03-06-2018 23:45
Best Answer03-18-2018 03:27
03-18-2018 03:27
Still does NOT work.
