03-09-2019 01:20
03-09-2019 01:20
Hi, since 2 March I have had syncing problems. I tried all the troubleshooting steps and nothing worked. Then I removed the tracker from the account and now it will not connect although it says that it has found it. I have noticed that this is a common issue and would like to know what you are planning on doing to solve it. I also need to know what I can do now to be able to use it as it was intended. Thank you.
Best Answer03-09-2019 01:43
03-09-2019 01:43
You probably won't get an answer to your question on fitbit's plans as customer support do not monitor these forums. You could ask them via contact.fitbit.com
In the meantime, without knowing what steps you have tried so far, here's my list of things to try. Hopefully there will be something there you haven't tried:
Assuming you get it sorted ok, if it should happen again then I would not recommend removing the fitbit from your account as this can lead to loss of unsynced data and make it harder to fix. The steps above are safe and should be tried first.
Best Answer03-09-2019 03:18
03-09-2019 03:18
