11-19-2016 18:06
11-19-2016 18:06
Best Answer11-19-2016 22:04
11-19-2016 22:04
11-19-2016 19:21
11-19-2016 19:21
Best Answer11-19-2016 19:58
11-19-2016 19:58
11-19-2016 22:04
11-20-2016 21:06
11-20-2016 21:06
Best Answer11-20-2016 21:10
11-20-2016 21:10
Best Answer11-22-2016 05:58
11-22-2016 05:58
Hi there @tbruce26 and @notoyaarthur, let me give you a warm welcome and I was just realizing the hard time both of you had with the syncing issues of your tracker.
Although I'm glad to hear with your solution @tbruce26 both were able to sync.
If you have lost part of your numbers due to this issue, remember that you can manually add an activity to average the steps for the days you lost. It wouldn't be the same, but it will be a workaround to recover those days.
See you around and let me know if you have additional questions.
05-07-2017 16:16
05-07-2017 16:16
My alta has not sync since April 23 deleted and re downloaded app nothing worked so I hit forget on bluetooth and now when I scan it doesn't pick it up
Beyond frustrated
Best Answer06-26-2017 18:37
06-26-2017 18:37
Mine started doing the same thing last night. Very frustrated. Need help.
Best Answer07-04-2017 05:33
07-04-2017 05:33
Welcome aboard the Fitbit Community @Barb1973 and @Chloe124. Its been a few days since you updated this thread and I'm wondering how it goes?
If the issue still persists in your case @Barb1973, you can try to paired your tracker again. For more instructions this post will guide you through.
@Chloe124 have you tried the other recommendations from this thread? Also I would like to know more details in specific of what information you are not able to see. Not all the scenarios are identical and this information is key to know more about the issue.
See you until the next one!
