03-28-2016 10:26
03-28-2016 10:26
Best Answer03-28-2016 10:29
03-28-2016 10:29
05:31
06:29
04-04-2016
05:31
06:29
Hey there @Sandishmily it's nice to see you around more often!
Have you tried restarting your tracker and then follow the steps provided here.
I hope this helps, let me know how it goes! ![]()
Best Answer04-04-2016 07:37
04-04-2016 07:37
04:15
06:29
04-05-2016
04:15
06:29
Thanks for the update my friend @Sandishmily!
Have you checked your Bluetooth and Internet connection are working correctly? If they're, I'd suggest you uninstall and reinstall the Fitbit App and then try syncing your tracker one more time.
Hope this helps, let me know if it works! ![]()
Best Answer04-05-2016 04:22
04-05-2016 04:22
Best Answer04-05-2016 07:44
04-05-2016 07:44
Best Answer04-05-2016 08:29
04-05-2016 08:29
Best Answer04-05-2016 08:49
04-05-2016 08:49
