09-18-2016 20:20
09-18-2016 20:20
Best Answer09-19-2016 15:17
09-19-2016 15:17
@Brittnieeboo I recommend restarting the Charge HR and then giving this setup flow a try. Let me know if you get stuck at any specific point in the process or are able to complete the setup.
09-19-2016 15:31
09-19-2016 15:31
Best Answer09-21-2016 07:16
09-21-2016 07:16
Welcome to the Community @Brittnieeboo is your tracker set up already? If what you are experiencing is merely syncing issue with your Galaxy S6, I recommend you following the steps on this post about Problems syncing my tracker - Android App
Hope it helps!
Parliamo di calcio Qual è la tua squadra di calcio preferita?
