So bit update thought I do a new thread cause the other is buried with other post .
So after countless times of uninstalling , reinstall , changes phones , turning off on phone and watch I think I found a work around that works .
So if you find your dropping connection from bluettooth or just won't sync , or no notifications comming in try this -
Tested on Honor 9 - Honor View 10 - Google pixel - oneplus5 - with good results .
Please Allow a good 30 sec for it to sync .
1 go to settings
2 All apps
3 show systems processes
4 Find Bluetooth
5 clear chache
6 clear storage
7 Go back to Fitbit App
8 let the App resync
DO NOT PAIR MANUALLY
You can see i syncing by the first bit app the WiFi icon will go green when synced and stay that way .
Worked for me several times and better than uninstall reinstall .
I did see this fix on the forum but can't think who posted it so just reposting
Try it see if it works - Fitbit please sort this out asap
@Ta2man wrote:So bit update thought I do a new thread cause the other is buried with other post .
1 go to settings
2 All apps
4 Find Bluetooth
5 clear chache
6 clear storage
I'm using the Ionic with the OnePlus 5T and have been experiencing loss of Bluetooth connection with the Ionic after I pair up some BT headphones (Zolo Liberty) with the phone. I'll give this a try and see if the connectivity issues get better. Thanks for the info!
I've been having the saps problems with my fitbit verda and onePlus 5T. However, i din't understand the steos you're talking about. Z bit more exolanation olease?
