01-09-2020
13:03
16:34
RicardoFitbit
01-09-2020
13:03
16:34
RicardoFitbit
First day using my watch and it keeps disconnecting from my phone. I've tried restarting both my phone and watch. Deleted and reconnected watch from both phone and fitbit app. Made sure all the settings were correct and turned on. It keeps giving me a notice that says "no internet connection. Make sure your phone is connected, then sync your device using the fitbit mobile app."
I have disconnected and reconnected wifi, my phone, the app.
I am rarely getting my notifications or able to control my music.
Best Answer01-10-2020 16:34
01-10-2020 16:34
Hi @Chrissy16, welcome to the Community Forums!
First, I'd like to appreciate your effort and patience troubleshooting this situation prior to posting. To better assist you with this, can you please let me know when was the first time you experienced this inconvenience and how many times since then? Did you experienced such connection difficulties after updating to Android 10 or your phone is running Android 9?
If you haven't already done so, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your Android mobile device that's preventing the syncing procedure to be completed. Also, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes. You can also check: My Fitbit device isn't receiving notifications from my phone for the notifications issue you're experiencing.
Keep me posted.
Best Answer01-10-2020 16:55
01-10-2020 16:55
