Hello and thank you.
I recently received a Zip as a gift and had it connected to my previous phone (Droid Ultra) and worked like a charm.
However, I just replaced my phone, and now the new one will not under any circumstances sync with my Zip.
I've reinstalled the app, reset my Zip, restarted my phone, etc. and nothing will work. Not only does it not sync, upon searching for Bluetooth devices from my phone (with Bluetooth enabled of course) it does not discover my Zip when sitting two inches away.
Is there a reason my Zip isn't broadcasting a signal? My computer did not locate it either on a Bluetooth scan.
I noticed you are new around in our community, welcome aboard @groundzero55. Make sure your new mobile device is listed in our support device. If it does, then try with the following article: I can't sync my tracker, for additional help tips. Keep in mind that your Zip does not sync as any other conventional Bluetooth devices. Make sure also your phone is not set in power saving mode.
Also if you are trying to sync from your Android device and you are near of your wireless sync dongle of your computer try to disconnect it as it might interfering with your phone.
Let me know how it goes. I'll be around. ![]()
Thank you for keep me posted @groundzero55. It's weird that is asking you for a PIN or passkey as you said. This should not be happening. Are you trying to use the bluetooth configuration of your phone. Remember that the set up process is only possible through the option of your Fitbit app. I recommend to review the following article: I'm having trouble setting up my tracker. If this is not helping then my last recommendation is to contact our customer support team.
Hope this helps. See ya around my friend.
