06-26-2016 07:40
06-26-2016 07:40
Best Answer06-27-2016 16:54
06-27-2016 16:54
@Okieoliveoyl I recommend restarting your Charge and then giving it another try. Let me know if that helps.
06-27-2016 16:54
06-27-2016 16:54
06-28-2016 06:37
06-28-2016 06:37
Thank you so much! That worked!
09-12-2016 20:09
09-12-2016 20:09
Best Answer09-13-2016 10:28
09-13-2016 10:28
http://help.fitbit.com/articles/en_US/Help_article/1186 see if that will help. That's what i did to reset my charge.
Best Answer09-14-2016 08:47
09-14-2016 08:47
Best Answer09-19-2016 09:19 - edited 09-19-2016 09:19
if you click the "restarting your charge" link posted above, it will take you to a page with instructions on resetting. Scroll down the page a bit and you will see Alta, Charge & Charge HR and other Fitbit products listed. Click on the Charge & Charge HR link and it will give instructionsf for the Charge (if this is the Fitbit that you have). If you have a different fitbit, click on the link to the one you have.
