08-03-2018 00:57
08-03-2018 00:57
Hello, only the right LED light is working. I have restarted it twice by pressing the left and bottom right buttons but still not working. I've also noticed that bluetooth keeps unpairing itself and I have syncing issues.
Very disappointed, as I had a Fitbit Surge which also unglued around the strap and practically has fallen apart. So I got this Blaze knowing the straps can be at least removed, now the LED light has gone and only had a couple of months
Can you help please?
Best Answer08-03-2018 02:07
08-03-2018 02:07
Unfortunately the restart procedure is the only real tool we have for fixing problems and if it's a hardware problem then that's not going to help. I think your best bet is to contact customer support as this may end up with a warranty replacement: contact.fitbit.com
