Hello @Julzei!
This might be happening because the P20 Pro is not currently in our supported devices list. This means that there might be some issues like that one that you are experiencing.
I would like to mention that there are some users who can sync with non-compatible devices after trying the steps on this help article. If your phone meets the minimum requirements Android 4.4 and Bluetooth 4.0 there is a possibility that it can sync, but we cannot guarantee it.
Let me know if you have any other questions.
Hi,
I'm also having trouble using the Fitbit versa with Huawei p20.
The versa pairs/links with the phone fine in terms of account and apps etc but I'm not receiving any texts or call notifications on the versa.
Have I set it up incorrectly or is there anything else I need to to e.g download an app?
Many thanks for any help/suggestions
Welcome to the Forums @SunsetRunner.
Like I mentioned above, it might be related to the fact that the P20 Pro is not currently on the supported devices list.
Be sure to follow the steps I link to above, there is a chance that they will be helpful although we cannot guarantee it.
Let me know if you have any further questions.
I've found that the only way for notifications to work is by keeping the app open in the app drawer. Soon as i close it, notifications stop. Soon as I re-open the app, sync it to my versa and then leave it open in the background it's ok. Very odd, I believe it's because all day sync doesn't work even though it's on. Let me know if it helps!
Welcome to the Forums @DPerkins.
Thanks for sharing your experience on the matter.
That could definitely be it. It could be happening because the phone is not on the list and thus All-Day Sync can't establish a connection with the Fitbit at all times.
Let me know if there are any questions.
Fitbit will not communicate with commputer
Welcome to the Forums @boblamping.
If you haven't, please try to follow these steps. They will definitely help your Fitbit to work properly once again.
Let me know if there are any further questions.
