Android app when adding food used to have options to enter numbers (servings or quantities) then select drop down arrow for measurements (grams, ounces, pounds, tsp, tbsp, cups etc.) No longer there, missing? Called support they said there are no issues, uninstalled & reinstalled app...
Appreciate any fixes, tips, hints
16:52
12:34
08-23-2019
16:52
12:34
Hello @JL6500, welcome to the Community Forums! It's a pleasure to help you out with your concern.
First, I appreciate your effort and patience troubleshooting this situation with our Customer Support team prior to posting. To better assist you with this, can you please let me know which Android mobile device you're currently using to sync your Fitbit? Also, when was the first time you experienced this and how many times since then? In the meantime I receive your answers, please try the following steps:
Also, please make sure that the mobile device you're currently using is compatible with our products and services.
Keep me posted.
16:52
12:34
08-23-2019
16:52
12:34
Keep me posted.
