05-27-2019
12:34
06:43
LanuzaFitbit
05-27-2019
12:34
06:43
LanuzaFitbit
Hey,
I've learned the auto sync syncs every 10 minutes. I think that's too often. Is there a way to make it sync less often. Say, every two hours or less.
Is there an Android app that could possibly launch the Fitbit app a couple of times a day?
Appreciate the feedback!
Hello @Robert1988.
Thanks for sharing your thoughts and concerns on the matter.
Unfortunately there is not a way to have this happen or to reschedule how often the auto sync works. As a workaround, maybe you could try turning the Bluetooth off when it is not required. I understand that this is not ideal but it could work.
Additionally, maybe you could post about it in our Feature Suggestions board. That way, other users can comment and vote on the idea to show their support for your suggestion. If you do visit that board, be sure to read the FAQ to better understand how it works.
Let me know if there are any other questions on the matter.
