08-30-2021
20:16
07:41
BraulioFitbit
08-30-2021
20:16
07:41
BraulioFitbit
Every time I attempt to change the weighing method (ounce, gram, etc.), my drop down menu just flashes then vanishes. There is no way to select an option. Anyone else having this issue or know how to fix it? I'm on an Android phone when using the Fitbit app.
Welcome to the Fitbit Community @EoxieStar! Thanks for the details provided about the issue with the food log section.
Please check that you have the latest version of the Fitbit app installed from the Google Play or Play Store. For more information, see How do I update the Fitbit app. If the app is updated, please try to force stop the app from your phone's settings by going to Settings > Apps > Fitbit > Force Close.
See you around.
