07-22-2024 06:51
07-22-2024 06:51
I've tried selecting the three dots to 'edit' the sleep but that is all it allows, is the edit not deletion of the sleep log. Thanks in advance for any assistance!
Best Answer07-23-2024 12:57
07-23-2024 12:57
Hello @MBwalkingMB
When you tap on the Sleep duration tile to open the Sleep page and tap on the 3 vertical dots, you should see
Select Delete sleep to remove the "nap". Edit sleep only allows you to change the time that sleep started & ended.
Best Answer07-23-2024 15:28
07-23-2024 15:28
Best Answer07-24-2024 18:42
07-24-2024 18:42
I don't see any change with the past. Tap on the sleep season. Tap the 3 dots. Tap delete
