07-04-2018 01:06
07-04-2018 01:06
Fitbit app for android using very high amounts of battery usage. Phone can be fully charged 4hrs later it has used 60% of battery.. I have uninstalled app, till issue is fixed!! Not exceptable fitbit
07-04-2018 02:34 - edited 07-04-2018 03:02
I wonder if it's related to the ongoing issue with high background data usage documented here:
https://community.fitbit.com/t5/Android-App/High-Cellular-Data-Usage-In-The-Background/td-p/2808875
It might be worth keeping an eye on that to judge when it's safe to reinstall the app.
Best Answer07-04-2018 03:00
07-04-2018 03:00
Same here, along with high data usage...
The app uses between 10 and 15% of my battery!
I deactivated the "continous sync" and the "keep-alive widget".
"Always connected" option is on.
Phone : OnePlus 3, running Android 8.0.0 and FitBit app version 2.73.
07-04-2018 04:05
07-04-2018 04:05
Mine used 16% yesterday, also on Oneplus 3 running 2.73.
I've also disabled Always Connected and Keep-Alive Widget.
Never noticed such a high battery drain before.
J
07-04-2018 06:45
07-04-2018 06:45
I just noticed the same high battery drain myself. I'm not sure exactly when it started, but it's only been a few days. The Fitbit app drained my phone's battery from 100% to 50% while I slept last night!
This is completely unacceptable!
07-10-2018 11:13
07-10-2018 11:13
Can someone else try turning off NFC and seeing if that helps?
I turned mine off after weeks of grief and today I've only got 1% drain with all of the settings turned on.
Cheers,
J
