03-12-2018 21:42 - last edited on 03-14-2018 07:29 by RobertoME
Got my Huawei p smart 3 weeks ago. Worked fine with my charge fitbit for the 1st week now won't sync or even connect to my fitbit. Keeps saying its found me but won't connect? All ready uninstalled the app and reset down loaded. Any ideas please
Moderator Edit: Updated Subject For Clarity.
04-20-2018 13:12
04-20-2018 13:12
try this i have the honor 9 - Honor View 10
1 Go To Settings on Your Phone
2 Go To App & Notification
3 All Apps
4 Scroll To Fitbit App
5 Permission Toggle All On
6 Notifications - Make sure Toggle Is On , Make sure Enabled Sync Is on
7 Go to Battery
8 Choose Launch
9 Make Sure Automatically Is Toggled Off , Make sure In Manage Manually Auto Launch , Secondary Launch ,Run In Background Are All Toggled On
10 See if notifications work , You May Need to Restart Your Phone Once , Also You Can Turn Of Notifications Dots , And For Toast Notifications In Status Bar , Worked for me , Have been Getting Notifications for The Past 5 Hours , No Red Warning About Service Not Running , Still a Bit Of Delay in Getting a Notification But Least It's Working , Try It See If It Woks For You
03-14-2018 07:29 - edited 03-14-2018 07:30
Hello there @Tracymurray, nice to have you here as a new member of the Fitbit Community! It was found Huawei models are not compatible as the latest P8 and P9 lite due to issues with the Bluetooth.
About the model you mentioned, still there is not an official word, but is not in our list of compatible devices. Due to the large number of Android devices, Fitbit has not yet tested all models to guarantee its functionality. If a device is not listed on fitbit.com/devices, this means we haven’t yet tested it.
It would not hurt to try the following suggestions though: Having trouble syncing? (here's how to fix this).
Hope this helps and let me know how it goes.
04-19-2018 12:13
04-19-2018 12:13
@RobertoME@ will you be testing the compatibility of the Huawei P Smart? I am missing my syncing my alta on my app.
04-19-2018 23:27
04-19-2018 23:27
Please fit bit can you sort out syncing to huaweH P smart asap. Thank you
04-20-2018 13:12
04-20-2018 13:12
3 All Apps
7 Go to Battery
8 Choose Launch
04-20-2018 23:46
04-20-2018 23:46
Thank you, did this and it finally connected, I had to have a bit of patience after putting the PIN in, but it is connected and synced.
04-21-2018 23:34
04-21-2018 23:34
05-02-2018 04:55
05-02-2018 04:55
Hi there @Dottiesuzie, @Tracymurray and welcome aboard to the Fitbit Community @bowesvikki. My apologies for the late response.
About your concern @Dottiesuzie and @bowesvikki. This information is not disclose to any of the Moderators team. With the intention of not provide false expectations to our Community of Fitbit users, in the scenario the mobile phone in question is declare as not compatible. I know many users are eager to see more Huawei models among our compatible list and rest assure if I got more updates I will let you know.
@Ta2man great suggestion, I have seen you have mentioned this and it seem is working this workaround. I appreciate your help on this topic and I marking your post as solution. I believe other users might find useful your recommendations.
See you around. If I got more information, I will be happy to share it with all of you.
05-02-2018 22:22
05-02-2018 22:22
Good morning i have been successfully using the fitbit for the last week after doing what you said the only thing i cant get to work are the calls coming through as an alert on the fitbit? Have you had any trouble?
Many thanks
Tracy
05-03-2018 12:07
05-03-2018 12:07
05-03-2018 12:30
05-03-2018 12:30
try restarting the phone and the watch - that what kept happening tom and so i gave up i love huawei phones and honor but i ended up buying a galaxy a5 201`7 cause of the dame syncing issue
05-03-2018 23:13
05-03-2018 23:13
08-05-2018 03:43
08-05-2018 03:43
Tried this with my huawei p smart but it still doesn't work
08-05-2018 04:11
08-05-2018 04:11
09-16-2018 23:30
09-16-2018 23:30
I've scowered the community pages to find out how to sync my P20 and my wifes Y6.
The P20 will connect after leaving it to sync for like an hour or sometimes 2.
The Y6 cannot sync.
Essentially the dev guys at fitbit are substandard programmers and approach the bluetooth stack like amateurs.
To get around the fact they don't know how to adapt to timeouts in the stacks you have to use a compatible device to do the initial sync/pairing while logged into your account on that compatible phone.
When you log in again on the non-compatible phone the device will appear as it synced its paired device through the cloud.
Now my wifes Y6 actually syncs. It took me days to find this work around. I thought Id have to log in under to accounts under my phone and sync both our fitbits that way. It actually syncs better on the Y6 than on the P20 that would aleast after hours sunc/pair initially.
Basically the timeouts on the Y6 stack turn off the bluetooth while the fitbit is running through its trainsmash of syncing code.
So just sync on a compatible device while logged in and viola, it actually works.
09-16-2018 23:34
09-16-2018 23:34
Sync on a firends compatible phone while logged in. Then go back to your phone and the device will be synced. It worked for my wifes Y6 which would not initial sync no matter what shenanigans you tried.
Basically the fitbit programmers don't know how to write bluetooth code that can sync with differing timeouts. This effects the initial sync.
09-17-2018 03:32
09-17-2018 03:32
But the issue with this is that if the Fitbit that's connected to the one device to sync you don't get notifications from the device you want it to sync with you only get 1 set of notifications from the device it originally synced with because it can only be sync to 1 device at a time for notifications . That's my understanding unless I .Wrong
12-08-2018 23:27
12-08-2018 23:27
Me too.
01-01-2019 15:10
01-01-2019 15:10
I have had my fitbit for one year now and still will not sync with Huawei phone.
01-01-2019 15:34
01-01-2019 15:34
We all need to email Fitbit and Huawei
