06-10-2021
07:43
13:55
SilviaFitbit
06-10-2021
07:43
13:55
SilviaFitbit
I have several alarm on my android phone.
Is it possible to have them notified on Fitbit Sense when the alarm rings?
(WearOs does it 😉 )
Yes its possible
Check the setup up procedure
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Notifications Verify the top 4 items are correctly defined. Also App notifications and select any apps you want to hear from. In your case Clock
Though Clock alarm on the phone doesn't appear to issue a notification because the App immediately becomes active when the alarm arrives but there may be an option to make it issue a notification depending on phone and version.
Note 1: You may only get a 5 minute pre alarm alert notification on your watch which may suffice
Note 2: It may not work depending on do not disturb or sleep mode settings [on either phone or watch].
Note 3: There is a good Alarm app on the watch also, which has additional options, such as smart wake.
