05-21-2016 03:25
05-21-2016 03:25
Best Answer06-03-2016 02:10
06-03-2016 02:10
Hi @CHARLOTTE91
Have moved this thread from the Charge HR to the Android App section to increase the chance of getting a solution.
Your post will get more attention here.
Best Answer06-03-2016 09:11 - edited 06-03-2016 09:12
@CHARLOTTE91 We recently released the Fitbit App for Android, version 2.26 update. I recommend updating your app for 2.26 and then giving it another try.
Also worth noting, MobileRun uses your phone's GPS sensors.
Best Answer06-03-2016 11:45
06-03-2016 11:45
Charlotte, does your activity show pace information and has it synced to the dashboard at fitbit.com? If you have an exercise goal set, is it counted as one of your days? I've had a similar issue with displaying the wrong map, but I've not noticed the distance being incorrect.
