Hi Fitbit
I have a Charge 2 and a Huawei p9, and though it isn't on the list of phones that are compatible with the Charge 2, it works fine.
Does it mean that it will work as fine with the Versa, or is there any differents?
Best AnswerIf you look at the compatibility check at https://www.fitbit.com/devices,
after you enter the phone, it has a box for "Check tracker-specific features", makes me think there might be some things not compatible on all trackers, but that's all I know about it.
