Based on what I had seen over the forums, I tried using Mobile Track when bicycling. From what I can tell, it takes an awful long time to "finish" if I went for a longer ride. If my ride is about 2 hours, after finishing the ride, I kept getting "not responding, "report," "wait," or "ok" (to stop). I recall a few weeks ago, I kept hitting "wait" for a few hours before it showed a map. Performance problem?
Hi there @raoloka, nice to see you in this opportunity in the Fitbit Community! Probably due to the amount of data your app has recorded in the period of two hours it might take a while to compile the data of your exercise, or the memory capacity is not enough for this task causing the app crash. However I just brainstorming possible causes of the scenario you are experiencing.
I'm wondering if this is happening with shorter exercise versions of your daily routine, or is the behavior equally for any exercise you track? Also I'm wondering if you are exclusively using MobileTrack or you are referring to MobileRun? Note that these are two different features. In other words just to summarize; MobileTrack allows you to track your basic activity data with your phone without the need of a tracker and MobileRun uses your phone GPS along with your tracker's data to provide you GPS information.
In the meantime, I'm wondering if you have tried to clear the cache of your mobile App? If not please give it a try to see if this resolved the error you are seeing:
Log out from your Fitbit app and go to your phone settings. Access to the App manager option and look for the Fitbit app in your downloaded apps list. Once you are there, clear the app cache and data and proceed to "Force Stop" the app. Finish the workaround by restarting your phone. When your phone has initialized, go back to your app and try again.
See you later and keep me posted how it goes.
Best AnswerI replied from my email reader, but somehow it didn't make it to the forum ... But I tried the suggestion (clearing the cache and restarting). It didn't seem to work. In fact, it went back to the scenario where the app wouldn't even respond to touching the "pause" icon.
