02-27-2019
07:39
10:15
LanuzaFitbit
02-27-2019
07:39
10:15
LanuzaFitbit
When I first set my Fitbit up it synced fine. However, after about 5 hours it quit syncing. I've tried uninstalling, reinstall, reboot, sign out/in, reconnect. Checked all settings on my phone and app. There is nothing that has changed since first setting it up. Please tell me what needs to be done to get it to work. From what I've read it should connect with the 8.0 Oreo software. If not, I sure hope I can get my $ back.
Best Answer02-27-2019 18:57
02-27-2019 18:57
Is your error related to the post pinned above?
02-28-2019 07:17
02-28-2019 07:17
Best Answer02-28-2019 19:17
02-28-2019 19:17
Tried WIFI sync and it still didn't work.
Any solution??
Best Answer03-01-2019 10:17
03-01-2019 10:17
Welcome to the Forums @Japsey. Hello @Rich_Laue.
Thanks for sharing those details on the situation that you are experiencing and the steps that you have tried.
In this case I'd like to ask if you are getting some sort of error message and if so, what does it say. That should help us better understand what is going on.
Look forward to your reply.
03-01-2019 10:19
03-01-2019 10:19
Best Answer03-07-2019 09:48
03-07-2019 09:48
Hello @Japsey.
Thanks for reaching back me with that information. I apologize for the delay in my response.
In this case I'd like to ask if the situation has continued since your last post or if you have noticed any improvements.
03-07-2019 10:46
03-07-2019 10:46
Best Answer03-11-2019 11:55
03-11-2019 11:55
Hello @Japsey.
I apologize for the delay in my response. Thanks for letting me know.
What Fitbit are you trying to connect with your phone?
In the meantime please try to follow the steps listed in this help article:
Let me know how it goes or if you have any further questions.
