@Kellie2016 The Galaxy S7 is not currently listed as a supported device. I recommend following the same steps that I suggested regarding the Galaxy Note 5 here. It doesn't hurt to try set up but it isn't guaranteed that all features will fully function with a device that is not listed as supported here.
As an alternative, you can setup with a computer using the instructions here.
