05-14-2016 14:41
05-14-2016 14:41
Best Answer05-16-2016 04:12
05-16-2016 04:12
It's great to see you around @Jmillz. If your tracker is not syncing, I recommend verifying that it is paired. If you are not seeing the tracker's tile on the Dashboard that means that your tracker is not paired and that you need to follow the Setup Procedure directly from your computer. After setting up the Charge it will work properly.
See you around! ![]()
Best Answer05-16-2016 05:04
05-16-2016 05:04
Best Answer05-16-2016 05:53
05-16-2016 05:53
Thanks for the information @Jmillz. I recommend Restarting your Charge and after the restart process, follow the Setup Procedure directly from your Android device not computer.
Let me know the outcome. ![]()
Best Answer05-17-2016 03:55
05-17-2016 03:55
Best Answer05-24-2016 09:06
05-24-2016 09:06
Thanks for letting us know what's happening @Jmillz! Since you're trying to sync wiht your Tab 4, I'd recommend taking a look at this discussion I had with another user in regards to the syncing issue with the Android phone.
Hope that helps!
