02-21-2019 10:21
02-21-2019 10:21
My fit bit charge 3 is adding large amount of steps whilst driving even when my arm is not active ? How do I apply the or install the drive mode ? And on my fit bit charge 2 my steps counted live on my screen as I walked for example but the Fitbit charge 3 my steps are just updated here and there ? Any help please
Best Answer02-21-2019 10:14
02-21-2019 10:14
Hi if anyone could help my fit bit charge 3 is adding massive amount of steps whilst driving even when my arm is not active what can I do about this add the step count is not live as whilst I move on fit bit 2 the steps would go up on the screen on the my new Fitbit 3 they seem to just update when ever. ? Any help be grateful
Best Answer02-21-2019 10:41
02-21-2019 10:41
@Joshghz3 Welcome to the Community. You could try downloading the Indipendent app Travelbit if you are on Android or Drivebit if on IOS.
You have to activate them at the time of starting driving and end when you have finished. The apps will then create a driving activity for that period of time and remove any steps that have been accumulated.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer02-21-2019 11:00
02-21-2019 11:00
The paid version of travelbit has an option to auto record driving.
Best Answer02-23-2019 14:44
02-23-2019 14:44
Hi guys, travel bit and drive but are no longer in the Android app store. Gutted as I've been using them for a few years and they did a great job. Anyone know of any new similar apps?
Best Answer02-23-2019 15:35 - edited 02-23-2019 15:39
Try travelbit where you can contact the developer
https://play.google.com/store/apps/details?id=com.okiesmokie.travelbit_premium
Best Answer02-24-2019 04:33
02-24-2019 04:33
Best Answer02-24-2019 04:34
02-24-2019 04:34
I've also tried contacting the developer but I get no replies.
