My phone is not connecting, syncing or updating time to my Blaze when Bluetooth is connected. Says it cannot find the Blaze to sync
The usual things I try when I get syncing issues are:
Note that your fitbit only has enough storage to hold detailed data for 5 - 7 days between syncs. After that it starts holding data at a daily summary level which it can do for around 30 days before it starts deleting data. So, once you get the connection sorted, expect your data to look a little strange.
If none of the steps above work for you then it’s probably best to contact customer support via: contact.fitbit.com
